Hello, First off, I am new to mo 1
DanStro
First off, I am new to modeling vibration/dynamics in Abaqus so most likely there are some basic errors that I am making. I am trying to set up an analysis that includes setting a preload on a series of optics and then look at how that preloaded system reacts to a frequency sweep. This seems like it should be a pretty straightforward set up but I am in this vicious loop. I can create the steps to apply the preload but I can't then add a frequency step after those steps because that has to be the first step in the analysis. But, when I create the frequency model first and then apply the preloads I can't create the dynamic steps(s) that I need do the frequency sweep. I've tried restarts and initial state but I can't figure out the order of the steps to get what I need. For the frequency I don't need the preload but for the dynamics step(s) I will need them.
Dan
It is possible to define static general step first and then frequency extraction one. Just turn NLGEOM on for the static step and then select it as a step after which frequency extraction will be performed. After that you can add modal superposition procedure.
There are some examples in the documentation. For example "Vibration of a cable under tension".
That kills my convergence but I think that might be the only way to do this. Thanks FEA way.
You can try with linear (NLGEOM = OFF) general static step before frequency extraction. It should work too.
I think that because of all of the edge-surface contacts that there will be a relatively large amount of rigid body movement while all of the contacts are being initialized, so I am not sure I can get with that.
Eigenfrequency extraction analysis is linear anyway and it can’t handle nonlinear contact (unless it’s complex eigenfrequency extraction). Thus I suggest turning these contacts to tie constraint. It can be easily done using „Find Contact Pairs” tool with „Show previously created interactions and ties” option on.
That is why I need a step to set the contacts, to keep the convergence well behaved I am using a quasi-static dynamics step with a displacement of the retainer, then I replace the displacement with the desired preload in a (now)general static step. Sometimes if I just jump right into a general static with the desired preload the convergence is really poor because of how 'inaccurately' the CAD model places the parts in contact. As long as I don't go overboard with the amount of displacement, and I don't have plasticity defined, even if I overshoot the amount displacement needed the preload step will bring everything back to where it should be. I don't think Tie constraints will work because after I get all of this done I will be putting the system through shock-vibe and I want to see what happens to the stresses/positions. But, depending on the specific requirements, I need to go through the frequency step to get to the desired goal.
Which dynamic analysis step do you currently use after eigenfrequency extraction ? I suppose it's steady-state dynamics. If yes then you can try its direct-solution equivalent. It doesn't need preceding eigenfrequency extraction step since it's not modal superposition procedure.
