Contact US
Self Priming Pumps Queries (Sanaitary Water Service)
Hi Guys,
Just wanted to know couple things with self priming pumps.
1. If the pump manufacturer says it is capable of suction lift of 6 Meters , then that means as long distance from highest point of the suction pipe to the surface of liquid plus head losses on the suction piping should be less than 6 meters for the pump to work?
2. I suppose I need to make sure that there is enough NPSH margin at the centerline of the pump impeller also?
3. For power calculation, do I need to add the suction lift (meaning differential head of the pump plus suction lift).
4. Is a foot valve mandatory for self priming pump? Or these pumps can work without foot valves also.
Thank you so much in advance.
Tilas
RE: Self Priming Pumps Queries (Sanaitary Water Service)
1. Yes
2.yes
3. Total head for power calculations is measured from supply level to discharge level plus all losses - use lowest level in the sump in the calculation.
4.depends on pump and system design - foot valves on sanitary pumps are /can be a major problem
Hi Artisi,
Thank you so much for your response.
Tilas
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
