ASTM A351 CK3MCuN is a 6% Mo Super
ASTM A351 CK3MCuN is a 6% Mo Super Austenitic Grade of Stainless Steel. For the Gas flowline service with 5.22% mole H2S, is this material is suitable for the service? How can we interpret this with ISO 15156-3 Standard. Please suggest
RE: ASTM A351 CK3MCuN is a 6% Mo Super
By consulting Table A.8 and confirming that the heat treatment conditions and 100 HRB hardness maximum criteria are met whilst assessing whether:
a) there is less than 50 ppm of chloride in the fluid stream
or failing that
b) that the temperature does not exceed 60 deg C and that the partial pressure of H2S, calculated in accordance with Annex C of ISO 15156-2 and Technical Circular 1 Link does not exceed 100 kPa
Steve Jones
Corrosion Management Consultant
www.linkedin.com/in/drstevejones
All answers are personal opinions only and are in no way connected with any employer.
Thanks for the suggestion.
But, as per table A.8 ISO 15156-3 it is mentioned as "Material have been used without restriction on P H2S, temperature , pH in production environment. Only Chloride Conc. Max 50 mg/l to be checked. If the temperature is exceeding on the 60 Deg C, can we interpret second row of Table A.8. Please advice.
It's either a) or b). So, if you exceed 60 deg C and/or 100 kPa pH2S, then you will either have to have up to 50 ppm chloride, or, if not, you will have to undertake qualification corrosion testing.
Steve Jones
Thanks Steve Jones for the expert advice. This really Helps !!
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Integrating the Engineering Ecosystem
Aras Innovator provides multiple options for integrating data between systems, depending on the scenario. Utilizing the right approach to meet specific business requirements is vital. These needs range from authoring tools, federating data from various and dissimilar databases, and triggering processes and workflows. Download Now
Research Report - Simulation-Driven Design for SOLIDWORKS Users
In this engineering.com research report, we discuss the rising role of simulation and the paradigm shift commonly called the democratization of simulation. In particular, we focus on how SOLIDWORKS users can take advantage of simulation-driven design through two analysis tools: SOLIDWORKS Simulation and 3DEXPERIENCE WORKS. Download Now
White Paper - Industry 4.0 and the Future of Engineering Education
With industries becoming more automated, more tech-driven and more complex, engineers need to keep their skills and knowledge up to date in order to stay on top of this wave—and to be prepared for the Industry 4.0 future. The University of Cincinnati offers two online Master of Engineering degree programs designed specifically for practicing engineers. Download Now
eBook - The Design Gridlock Manifesto
In this eBook, you’ll learn 6 ways old CAD technology slows your company down and hear how design teams have put those problems to rest. “The Design Gridlock Manifesto” shares first-hand modern CAD experiences from 15 companies around the world. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
