Determine the area of a region with stress greater than the predetermined value
AnPham
VN
Hi everyone,
After completing the solution, I can exploit the results on the body.
But how can I determine the area of a region with stress (or any result) greater than the predetermined value?
For example, the figure below is the stress result of one face, I want to calculate the area of the region with stress greater than 80MPa.
Is this possible?
Thank you.
Not sure, but for sure one can write a script for this.
Pseudo code:
1. Loop through all elements and get stresses
If it is above certain stress get node number and get area of the element and add it to total area, if not then do not do anything and go to the next Element until loop is complete.
This works in apdl (so could be a command snippet in solution in WB)
Code:
/POST1
*get,ncount2,elem,,count
*dim,scrap2,array,ncount2,7 ! temporary array, length = ncount2
*dim,arlart,array,ncount2,3 ! temporary array, length = ncount2
! getting component stresses for all the elements and writing them in txt file
alls
SET,LAST
*VGET,scrap2(1,1),elem, , elist
etable,seq,s,eqv
*vget,scrap2(1,2),elem,,etab,seq
totarea=0
b=1
*do,i,1,ncount2,1
*if,scrap2(i,2),GT,4,THEN ! change this to the stress criteria needed (GT means greater then)
*get,arel,elem,i,AREA
totarea=totarea+arel
arlart(b,2)=i
arlart(b,3)=arel
b=b+1
*endif
*enddo
Thank you for your reply.
I tried that code but the result was not satisfactory.
I understand in that code that the elements with stress greater than the predetermined value and the surface area of the elements are calculated.
In the case I am trying to achieve, it is the area on a surface. That means, there is only one side of an element on that surface.
I think this will be very difficult.
Anyway, thank you for your help.
Though you used shell element so I tried that on them and it was OK.
If you need the surface area on a 3d part then this should work.
We can add membrane element on that surface to get surface stresses something that is common and often used, then filter in the *do loop for elements only of type 2 say which are membrane elements (surface).
Below is an example (1x1x0.2 m block with applied pressure on one end) where the membrane elements are placed on top surface of the block to get accurate surface stresses, thus their total area is 1m2, so if we set the GT condition to 0, then we should get 1, and if we set it to high stresses say 100E6 Pa, then we should get zero area (since the applied stress is 1E6 Pa), so it works here - so perhaps something like this could be used:
Code:
/clear
/prep7
W=1	! Width
L=1	! Length
TH=0.2	! Thickness
ET,1,SOLID185
ET,2,SHELL181
KEYOPT,2,1,1
KEYOPT,2,3,0
KEYOPT,2,5,0
KEYOPT,2,8,0
KEYOPT,2,9,0
KEYOPT,2,10,0
KEYOPT,2,11,0
sect,1,shell,,
secdata, 0.0000005,1,0.0,3
secoffset,MID
seccontrol,,,, , , ,
MPTEMP,,,,,,,,  ! Material prop.
MPTEMP,1,0
MPDATA,EX,1,,200E9
MPDATA,PRXY,1,,0.3
MPDATA,KXX,1,,51
MPDATA,ALPX,1,,0.0000115
BLOCK,0,W,0,L,0,TH,	!Define a block
ASEL,S,AREA,,4
SFA,ALL,1,PRES,1E6
ALLSEL,ALL
ASEL,S,AREA,,3
DA,ALL,ALL,0
ALLSEL,ALL
ESIZE,0.05,0	! Mesh
VMESH,ALL
type,2
nsel,s,loc,Z,0.2
esln,s,,,,
esurf
allsel,all
/SOL
ANTYPE,0
TREF,0	! Ref temp is 0 here
/STATUS,SOLU
SOLVE
FINISH
/POST1
allsel,all
*dim,eltyp,array,1,1 ! temporary array, length = ncount2
SET,LAST
etable,seq,s,eqv
totarea=0
b=1
*do,i,1,ncount2,1
*vget,eltyp(1),elem,i,ATTR,TYPE
*if,scrap2(i,2),GT,0,AND,eltyp(1),EQ,2,THEN ! change this to the stress criteria needed (GT means greater then)
arlart(b,2)=i
arlart(b,3)=arel
b=b+1
*endif
*enddo
Thank you very much
I have understood and applied successfully.
No worries AnPham, glad I could help. You have helped a lot here but also in the ansys student community site - it is much appreciated that you continue doing that.
Thank you
Erik (jj77) :)
