Contact US
Mag Drive Pumps
Mag Drive Pumps
Mag Drive Pumps
Hi, I want to know about Mag Drive pumps
- I am told solid contents are not desirable in services, is there a limit ( average and approx)
- what are the limitations of Mag Drive pumps
- Any Reliability figures available
- What is the critical most failure component within Mag Drive pumps
Thanks a lot !
RE: Mag Drive Pumps
If it is one with a bearing in the working fluid than the debris tolerance will depend on the bearing materials.
In most cases this is none. Usually any debris will be a disaster.
The biggest killer of these is over heating.
The working fluid is what cools them.
Overloading them and slipping the drive generates a lot of heat, and there is then no flow to remove it.
What are you wanting to pump?
Why have you chosen a mag drive?
They are great for specific applications but they are expensive.
RE: Mag Drive Pumps
Ed, Thanks a lot
Bitumen is the service , high temperature , 140 Deg C Mechanical seals are not available hence mag Drive
RE: Mag Drive Pumps
IDEX Viking positive displacement pumps have been pumping Bitumen with a variety of seals for decades.
You may require a steam quench for the seal....
IMHO, this would be a better choice than your Mag Drive idea...
http://vp.salesmrc.com/pdfs/Form381_Asphalt_Indust...
MJCronin
Sr. Process Engineer
RE: Mag Drive Pumps
Thank you MJ!
RE: Mag Drive Pumps
Hot, viscus, potentially abrasive, are all reasons to NOT use mag drive.
Yes, these require special seal arrangements.
RE: Mag Drive Pumps
We used Viking helical gear pumps in 140-170degC operating temp range bitumen service, with Plan 52 John Crane seals with fin fan cooler and recirc pump in the barrier fluid circuit to handle a wide turndown (down to less than 10:1 on speed). The VFD motor had an aux cooling fan to keep the motor windings cool at low speed operation. Pump casing was Thermon HPT style electric heat traced and insulated. Getting the seal system requirements firmed up took months.
Would have thought mag drive pumps would not even figure in the selection options list for this application.
RE: Mag Drive Pumps
Thanks a lot George. That's a useful input
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
