Contact US
RSA_Piles rotation
RSA_Piles rotation
RSA_Piles rotation
Hello Everyone,
I am currently running a response spectrum analysis on a bridge model built on drilled shaft. The way I modeled the piles, is divided into 5' frames and assigned a line spring to each one. I had already calculated the PY and imported it into CSI Bridge.
However I have two identical piles and only the left one is rotating tremendously by about 940 rad/in. I cannot figure why. I checked restraints, the PY values but the Left pile acting in unstable way.
Any advise will be greatly appreciated.
Thanks!
RE: RSA_Piles rotation
There's not enough information to understand why the rotation is so large, some diagrams showing rotation and a deflected shape would be useful.
In general I don't like using "infinitely stiff" supports at pile bases, use springs instead for the pile vertical and horizontal stiffnesses. Even if you dont have these to hand you can eyeball them in, based on say 10-20mm vertical deflection and doing a small parametric study to check the sensitivity of these values.
Also be careful of units you use, are the springs assigned to the nodes or the elements?
gl
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
