What is the advantage of using a multi-ratio CT vs a single ratio CT?
I'm looking at some new 12kV switchgear to shed load from the existing switchgears. All the existing have single ratio 600/5 CTs on their feeder circuits for protective relaying, but the new switchgear has 1200/5 multi-ratio CTs - set at 1200/5 from the factory.
It would be more intuitive imho if all the settings matched each other: old going to new. Is it worth telling them to change the ratio ?
RE: What is the advantage of using a multi-ratio CT vs a single ratio CT?
Multi-ratio CTs make life easier during design - no need to try to size per expected load. In olden days, the CTs served both protective relays and analog ammeters. The maximum range of the ammeter was based on the CT ratio. So the CT needed to roughly match the expected load current. A 0-1500 A ammeter on a feeder with the maximum load of 100 A wouldn't be popular. These days, there are no ammeters, so not as big an issue.
But you don't get this convenience without a price. Tapping down a 1200/5 CT to 200/5 also reduces the relay accuracy class of the CT dramatically.
Also, there is a lower limit for relay pickup settings - and it isn't always all that low - especially for SEL relays.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - The Evolving Landscape of Commercial Battery-Powered Trucks
What’s driving the evolving landscape of truck electrification? What are the barriers, motivators and strategies for accelerating the electric transition? What insights and resources are available for today’s design engineers working to achieve industry disruption and evolution? For answers to these and other pertinent questions, read this white paper. Download Now
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
