TSMC 65nm sealring LVS error
Hi
I am using TSMC 65nm PDK for tape out. The LVS was clean before I add the sealring. However, when I added the sealring, the LVS complaint about 2 things:
(A) Stamping conflict. Net VSS is selected for stamping.
(B) the additional nets and instance. The additional device from the sealring is a lot of parallel conected caps, called C(CM).
For (A), stamping conflict, I confirmed that it is due to the sealring has OD-CO combination and LVS consider it as a substrate pin. But the sealring is not connected to the core substrate VSS pin. The way I solved it was enclosing the sealring by pusb2 layer. Do you think this is the right way to do so? Or should I connect the seal ring to the core VSS?
For (B), I checked the LVS rule file and isolated the device and discovered that a subcell in sealring lib is the reason of this C(CM) device. The LVS rule considers the combined layers in the subcell as CM caps. By checking the LVS rule file I have, I can think of 2 ways to solve this LVS error. The first way is: I commented the line in LVS rule file that defines the C(CM). Then The LVS could not recognize the C(CM) hence it is clean again. The second way I can think of is that can I ask if there is a schematic or spice/LVS netlist file associate with the sealring layout? (for example, the ESD devices has no schematic but a spice model for LVS)
Thank you very much
Al
RE: TSMC 65nm sealring LVS error
I suppose if you thought for some crazy reason that you were talking to someone intimately familiar with the TSMC PDK (whatever that is) and your design, your posting might make some marginal sense. This sounds like something you should ask your TAs, or professor, or even your TSMC rep.
TTFN (ta ta for now)
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Strategies to Secure Connected Cars with Firewalls
White-hat hackers have demonstrated gaining remote access to dashboard functions and transmissions of connected vehicles. That makes a firewall a vital component of a multilayered approach to vehicle security as well as overall vehicle safety and reliability. Learn strategies to secure with firewalls. Download Now
White Paper - Model Based Engineering for Wire Harness Manufacturing
As complexity rises, current harness manufacturing methods are struggling to keep pace due to manual data exchanges and the inability to capture tribal knowledge. A model-based wire harness manufacturing engineering flow automates data exchange and captures tribal knowledge through design rules to help harness manufacturers improve harness quality and boost efficiency. Download Now
White Paper - What is Generative Design and Why Do You Need It?
Engineers are being asked to produce more sophisticated designs under a perfect storm of complexity, cost, and change management pressures. Generative design empowers automotive design teams to navigate this storm by employing automation, data re-use and synchronization, and framing design in the context of a full vehicle platform. Download Now
eBook - Simulation-Driven Design with SOLIDWORKS
Simulation-driven design can reduce the time and cost of product development. In this engineering.com eBook, we’ll explore how SOLIDWORKS users can access simulation-driven design through the SOLIDWORKS Simulation suite of analysis tools. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
