Unanchored tank modal analysis
Hi
Is the modal analysis of unanchored tanks (simply placed on the ground) with abaqus any reliable given the nonlinear nature of the problem? I've obtained some results for convective and impulsive modes but don't know if they are any valid or not.
RE: Unanchored tank modal analysis
It should be possible to obtain valuable results for this case in Abaqus. This software is made for nonlinearities and it can handle fluid-structure interaction (or acoustic-structural coupling actually) too. How did you model the problem ?
There are some papers about it. For example these two:
- "Nonlinear Finite Element Analysis of Unanchored Steel Liquid Storage Tanks Subjected to Seismic Loadings" by H.N. Phan, F. Paolacii and P. Mongabure
- "Fluid-Structure Interaction Problems: An Application to Anchored and Unanchored Steel Storage Tanks Subjected to Seismic Loadings" by H.N. Phan, F. Paolacii
we have discussed this and shown that acoustic elements can be used (it can be hard to identify modes, but they work).
So if it is not anchored you can let it sit on top of the ground and have frictional contact between the tank and the ground, and then run it with nonlinear transient dynamics say typically with seismic loads (you cannot use modal since it is a linear analysis and does not account for the complex contact between the two structures).
Now I have never done anything like that (measurements or FEA), so I cannot comment if the modes you calculate (probably free suspended tank), are close to the real modes when the structure rests on the ground - obviously the BC are quite different.
In any way seismic transient nonlinear transient dynamic analysis uses implicit time integration since it needs to account for all nonlinearities (contact, material geometry), and thus a mode superposition is not used, but an implicit scheme, so modes are not used.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Strategies to Secure Connected Cars with Firewalls
White-hat hackers have demonstrated gaining remote access to dashboard functions and transmissions of connected vehicles. That makes a firewall a vital component of a multilayered approach to vehicle security as well as overall vehicle safety and reliability. Learn strategies to secure with firewalls. Download Now
White Paper - Model Based Engineering for Wire Harness Manufacturing
As complexity rises, current harness manufacturing methods are struggling to keep pace due to manual data exchanges and the inability to capture tribal knowledge. A model-based wire harness manufacturing engineering flow automates data exchange and captures tribal knowledge through design rules to help harness manufacturers improve harness quality and boost efficiency. Download Now
White Paper - What is Generative Design and Why Do You Need It?
Engineers are being asked to produce more sophisticated designs under a perfect storm of complexity, cost, and change management pressures. Generative design empowers automotive design teams to navigate this storm by employing automation, data re-use and synchronization, and framing design in the context of a full vehicle platform. Download Now
eBook - Simulation-Driven Design with SOLIDWORKS
Simulation-driven design can reduce the time and cost of product development. In this engineering.com eBook, we’ll explore how SOLIDWORKS users can access simulation-driven design through the SOLIDWORKS Simulation suite of analysis tools. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
