Min distance "A" between reinforcing plate and vertical weld joint
Good day
I have a distance (A)125mm between periphery of reinforcing plate and vertical weld joint of tank.
In API 650 it shown as A=150mm (Fig. 5.6).
Can we reduce distance "A" to 125mm (with RT or PWHT)?
Dia. of nozzle 6"
WTH of tank 8mm
Water Storage tank.
Reinforcing plate type RTR
RE: Min distance "A" between reinforcing plate and vertical weld joint
API does not have a rule that reduces "A" below 150 mm.
