DFLUX SUBROUTINE
DFLUX SUBROUTINE
DFLUX SUBROUTINE
Dear all
I have written a user subroutine in Fortran for Double Ellipsoidal heat input.The purpose is to to do welding analysis in Abaqus for a 3D rectangular plate.But after running the code it is showing Problem during compilation.Any please pointout what is the error in the code.
SUBROUTINE DFLUX(FLUX,SOL,KSTEP,KINC,TIME,NOEL,NPT,COORDS,
1 JLTYP,TEMP,PRESS,SNAME)
INCLUDE 'ABA_PARAM.INC'
DIMENSION FLUX(2),TIME(2),COORDS(3)
CHARACTER*80 SNAME
a=0.003
b=0.003
cf=0.001
c=0.003
pi=3.1415
eff=0.8
V=24
v=0.00166
I=100
x0=0
y0=0
z0=0
d=v*TIME(2)
t=TIME(2)
x1=COORDS(1)-x0
y1=COORDS(2)-y0
z1=COORDS(3)-(z0+d)
Q=((eff*V*I)/(v*.001))
A=-3*x1**2/a**2
B=-3*y1**2/b**2
C=-3*z1**2/c**2
D=6*Q*cf*1.732/(a*b*c*pi*sqrt(pi))
IF(KSTEP.EQ.1) then
H=D*EXP(A+B+C)
FLUX(1)=H
else
FLUX(1)=0
end if
return
end
RE: DFLUX SUBROUTINE
I'm not a Fortran expert, but isn't there an END IF missing?
Are variables in Fortran case sensitive?
Thank you Mustaine3
It was missing.I have corrected the code with END IF.Also change to capital letters.It is running successfully now.But after running the code I am not getting any change in temperature.Only it is showing the ambient temperature of 25 degree.Also it seems like it is not reading any heat input
Just for the record: Problems in compilation are usually written in the .log-file.
On topic: You could add something like "write(6,*) FLUX(1)" to your subroutine. By doing that, the value of FLUX(1) for each increment will be written into the .dat-file. If the values there are zero, you know that something is wrong with your subroutine.
However, I suggest to test any subroutine with a very simple model, so you can get an idea on how (or if) it behaves.
White Paper - Guide to Integrate Large-Format Additive
As with any new technology, getting into large-format 3D printing begins with investigation. The first question may be a simple one: what does “large-format” mean? For 3D printers, “large” is a relative term. Many extrusion-based (FFF) 3D printers are referred to as desktop machines, because they fit on table space. Some of these have very respectable build volumes – but when it comes to “large-format,” the machines will need their own dedicated floor space. Large-format 3D printers have significant build volumes and are most often found in professional settings, like manufacturing facilities and R&D centers. Download Now
eBook - Efficient and Effective Production Support with 3D Printed Jigs and Fixtures
Jigs and fixtures offer manufacturers a reliable process for delivering accurate, high-quality outcomes, whether for a specific part or feature, or for consistency across multiples of parts. Although the methodologies and materials for producing jigs and fixtures have evolved beyond the conventional metal tooling of years past, their position as a manufacturing staple remains constant due to the benefits they offer. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
