Elevator Rail Deflection Requirements
I am in the process of designing a elevator that is steel framed with metal studs. I need to provide rail support for the car as it travels up and down the elevator shaft. Loads are provided by the manufacturer for me to design my rails (simple enough). I am looking for some guidance as to what allowable deflection would be for these rails. I seem to remember a figure of H/1000 but I can't seem to find anything on the elevator shop drawings. Is H/1000 correct?
RE: Elevator Rail Deflection Requirements
I don't know if it's the latest version, but Google "ASME A17.1-2007/CSA B44-07". (I was able to find several free downloads on the first few hits.)
They have deflection requirements in there.
https://www.structuremag.org/?p=2580
"Allowable deflections for rail supports as required by the elevator code are 1/8-inch under normal loading and ¼-inch maximum with seismic activity."
eBook - Mastering Tolerances for Machined Parts
When making CNC machined parts, mastering tolerances can be challenging. Are general tolerances good enough? When does it make sense to call out for tighter tolerances? Do you need a better understanding of fits, datums, or GD&T? Learn about these topics and more in Xometry's new e-book. Download Now
eBook – How to Choose the Correct Corrosion Testing Method
When designing a metal component, engineers have to consider how susceptible certain alloys are to corrosion in the final product’s operating environment. In a recent study by NACE (National Association of Corrosion Engineers), it was estimated that the direct and indirect costs of corrosion in the United States is approximately 6.2% of the GDP. In 2016, that cost exceeded $1 trillion dollars for the first time. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
