Manufacture of rectangular HSS
DomDunk
CO
Only the three fabrication methods showed in the document below are permitted?
A fabricator want to fabricate a rectangular HSS by welding two plates (rolled in L section) in two corners of final HSS.
Daniel
I don't have the ASTM in front of me to confirm. But, isn't that a requirement of the ASTM that governs these HSS sections?
Now, it's not that you cannot create a box section a different way. But, it's no longer an HSS section and different design provisions may apply. Certainly you have greater residual stresses. Section properties would be a little difference as well. b/t ratios would be a little different. material properties would be different. et cetera.
Yes, the provisions are a bit different.
So, if a design a box section Can I weld the plates as I want?
If you want to make some custom composite sections knock yourself out; but do not expect them to follow any tabulated values for the sections you are trying to mimic.
Make sure you consider manufacturing. If you roll out a set of plates into Ls and weld them together along the length they won't be close to straight at the end of the process.
