NX11 - Drop Down code
Adding a drop down to a TBR file is simple enough. What I was wondering is if it is possible to add a drop down menu inside of another drop down menu?
Basically what I have is three different drop down buttons. These bring in parasolids.
Square Tbu'g Drop down will have a list of different size square tubing.
Round tubing will have a list of round tubing parasolids.
Steel Angles will have a dropdown list of several different sized steel angles.
My boss would like to know if we can create a drop down button called "Structural Shapes" that first has a drop down list of...
Square Tubing
Round Tubing
Steel Angles
Whichever one you select would then expand to a second list of the different sizes we have of that item.
Is this possible?
RE: NX11 - Drop Down code
Got it. Basically it was as simple as writing the dropdown inside the other dropdown. lol
Example....
BEGIN_DROPDOWN Shapes
DROPDOWN_STYLE AS_POPUP_MENU
COLUMN_DROPDOWN 1
BEGIN_DROPDOWN SQUARE TUB'G
COLUMN_DROPDOWN 1
BUTTON 3X3X325
LABEL 3" X 3" X 5/16" WT
STYLE Icon and Text
ACTION path to vb file\xxxxx.vb
BUTTON 4X4X325
LABEL 4" X 4" X 5/16" WT
STYLE Icon and Text
END_DROPDOWN
BEGIN_DROPDOWN Round TUB'G
COLUMN_DROPDOWN 1
BUTTON DIA3X325
LABEL 3" DIA X 5/16" WT
STYLE Icon and Text
BUTTON DIA4X325
LABEL 4" DIA X 5/16" WT
STYLE Icon and Text
END_DROPDOWN
END_DROPDOWN
I just never even considered the simplicity of it. lol
What I would still like to know however, is can one make it so the upper levels of the button are not selectable to run the VB code? Only selecting the lowest level will run the journal?
you have not considered using the reuse library ?
Tomas
I had mentioned using the Reuse Library with one Rectangular Tube, one Round Tube, and one Steel Angle and each would have a few parameters to change. That was shot down. He wants a button and just dead bodies.
eBook - Efficient and Effective Production Support with 3D Printed Jigs and Fixtures
Jigs and fixtures offer manufacturers a reliable process for delivering accurate, high-quality outcomes, whether for a specific part or feature, or for consistency across multiples of parts. Although the methodologies and materials for producing jigs and fixtures have evolved beyond the conventional metal tooling of years past, their position as a manufacturing staple remains constant due to the benefits they offer. Download Now
Overcoming Cutting Tool Challenges in Aerospace Machining
Aerospace manufacturing has always been on the cutting edge, from materials to production techniques. However, these two aspects of aerospace machining can conflict, as manufacturers strive to maintain machining efficiency with new materials by using new methods and cutting tools. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
