May 13, 2019 #1 DayaS Materials Joined May 13, 2019 Messages 1 Location NZ I got test results from Lab in MPa for tensile strength, I have old results from files for same film as N/25mm. Film thickeness for current results and old results = 110um (micron) How can I compare one with the other. thanks
May 14, 2019 #2 Compositepro Chemical Joined Oct 22, 2003 Messages 7,841 Location US a Pascal is one Newton/m2. The cross-sectional area of your sample is 110 micron (millionths of a meter) by 25 mm. You do the math. Upvote 0 Downvote
