Volumetric Expansion
Daniele1989
Automotive
IT
Hi all,
i need to understand how volume i increase in a chamber if i apply 10 bar pressure. Is there available a way to get this information?
Thank you
Could you provide more details about your case ? I'm not sure if I understand what you actually mean. Do you want to analyze an increase in volume of fluid (liquid/gas) in closed tank when pressure is decreased ?
Did you consider using the basic formula below ?
ΔV=(V/B)*Δp
where: ΔV - change in volume, V - initial volume, B - bulk modulus, Δp - change in pressure
Maybe author want to know change of structure volume, like toy balloon.
Deformed geometry can be exported back to the spaceclaim or designmodeler.
Link
Link
Thank you all.
@FEA_way i mean that i have a chamber that contains hydraulyc fluid, and i need to see how much volume i will have after 10 bar applied.
