Contact US
vs4 vertical pump
vs4 vertical pump
vs4 vertical pump
hi,
i have problem with vs4 vertical pump ,found high run out for the shaft so dismantle then straighten the shaft till run out reach 0.05,assembly and mechanically run test,after removing pump from test bed and measure run out for pump hup found it 0.16mm
RE: vs4 vertical pump
That shaft is probably supported by a simple bushing just below the stuffing box. Depending on the shaft size, the clearance in that bushing could be 0.15 mm or more. This could be interpreted as run out if the mechanic is not very careful about how he takes the reading.
Johnny Pellin
Check the shaft hub too, if it is round or not.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
