Contact US
Stress Analysis vs Stability Analysis for Aluminium Dome Roofs (Space Frames)
Hello dears,
Firstly, I wish all eng-tips people a successful day. I am a junior civil engineer has started to construct space frames such aluminium geodesic dome roofs. I would to ask some questions to clarify them on my mind and helps to other people concerning about these subjects.
1.When I design a dome roof, API 650 Annex G refers to stress analysis for design. But as I know, stability analysis is a factor also for design of space frames. What do you think about it? when I compare these analysis on my dome, stability design requires more stiff sections means heavier sections.
2. For beams under compression, there are some effective lengths issues for buckling(Now, the table has came to ur eyes). Normally, for space frames which have pinned connections, effective length factor is 1. But fixed connections decreases. Since, dome roof beams connecting a node plate by bolts, I've thought that these beams have fixed connections. So can I apply effective length factor as a calculated for fixed connections?
Thanks for answering
RE: Stress Analysis vs Stability Analysis for Aluminium Dome Roofs (Space Frames)
I've seen the bolted struct connections, but I would guess they are still pinned connections and not designed as moment connections. Even if they were moment connections, it would take some careful thought to figure out what that did to effective length. Specifically, you'd have a moment connection to a hub plate, but what keeps that hub from rotating is just similar connections to other struts. So if the hub can rotate, the struts can buckle on each side without rotational restraint.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
