i was hoping someone can help me with a bearing question. I'm currently building a tricycle, and i'm in a process of remaking the steering (old design had flaws). I have decided to try and use UCFL 204 bearing for the shaft (please see the picture, my apologies for my drawing skills). The top part of the shaft will have steering lever, and the bottom part of the shaft moves the plate, which is attached to front wheels with metal rods (its a tadpole trike, 2 wheels at the front) To my surprise the actual bearing is pretty loose in the casing. If i twist the shaft, the bearing moves in the case (despite me tightening the only screw on the casing). Is it normal for it to move under load? Can something be done, like welding the casing to the bearing, perhaps? I would rather not do any welding, as i'm building no-weld prototype. I'm thinking of using second bearing higher up on the shaft, as 1 bearing seems insufficient here, so perhaps that can help a bit, but i would appreciate any advice, as i have no experience with bearings. Thanks
