Safety on Pneumatic Valve Manifold
Hello, I'm working on development of pneumatic safety components. I'd like some help in understanding if there is a preference towards safe power in a valve manifold vs using a safety rated valve. Safe power to the manifold is a cheaper way to control multiple valves but does not offer the same level of safety as a redundant safe valve that is directly monitored. Do any of you have experience with this in designing a system and would your needs changed based on the safety circuit?
3D Scanning in the Automotive Industry
With over 100 years of production history, the automotive industry has been at the forefront of manufacturing technology since its inception. Whether the transformative technology of the day was the assembly line, the integration of robotics into the manufacturing process, or the switch from steel to aluminum frame chasses, the automotive industry has consistently implemented advanced technology into its manufacturing and production workflow to improve manufacturing and product performance. Today, the same is true. Download Now
Green light on lidar: Developing low cost systems for autonomous vehicles
Lidar has been around for quite some time, but to date, it’s been custom—and expensive. Right now, there isn’t a clear-cut solution that’s suitable for all applications, such as lidar in autonomous vehicles. As they explore options, optical and mechanical engineers are forced to make choices and tradeoffs during the design process. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
