Direct Logic 205 PLC controlling a stepper motor to be controlled by an Analog Voltage
Looks like I got in over my Head, I had used Click PLC's before so thought I could handle this project.
Goal: Use a capacitance sensor module that produces a 0-10V signal to determine position and maintain it. The sensor uses an Analog output where 1V = 1mm. If has an Analog Input used as a reference. I put in 1V it will provide an opto output stating it is in position when the the output matches. it also has a Vdif analog output that is + or - the difference from reference.
So I purchased a DL205 w/ DL262 CPU, an F2-8AD4DA-2 for the Analog inputs and outputs. An H2-CTRIO-2 for the stepper control to control a simple Sure step STP-DRV-6575 with STP-MTR-23055 motor.
I Configured the workbench for a step and direction motor. Drive is set up and self tests fine. but I am having trouble on where to begin with the ladder. They have an example, but unless I purchase the full software, I can't open it because it is more than 100 words. I am guessing because of all the included details.
what I want to do is:
when above the reference voltage drive the motor until it is in position then maintain the position. sounds simple , but this manual looks like greek to me.
any tips you think will help me is appreciated. i will search these forums to see if its been covered
thanks so much
thanks so much
"I am stuck on Band-Aid brand, 'cause they are stuck on me"
RE: Direct Logic 205 PLC controlling a stepper motor to be controlled by an Analog Voltage
Brad Waybright
It's all okay as long as it's okay.
thebard is probably correct but to help you get off dead center I'd cobble some ladder logic up that is rudimentary, just run a straight Bang-Bang.
A: Read the analog data
Compare the read number to the desired number.
IF greater than reverse direction
ELSE don't reverse direction
GOTO A:
This will probably cause erratic control but from this you will get a feel for the dynamics and can quickly improve the control. From here you'd probably want to work in a PID. There are a lot out there to choose from find one for the DL series.
Keith Cress
