Contact US
problem with installation of shell plates
Hello all,
I am working in the erection of the 4 courses of a API tank.
In the second course I found that one shell plate is shorter as per design drawings.
this generates a bigger gap for the welding ( 2mm in the bottom of the plate and 12mm in the top)
see attached sketch.
What could be a good solution?
I think in install back plates and fill the gap with welding.
Regards.
https://res.cloudinary.com/engineering-com/image/upload/v1557259920/tips/Drawing1-Model_np0qwy.pdf
RE: problem with installation of shell plates
IMO, the vendor, who prepared the plate shop drawing and made the cut, is responsible for the error. Or, you may inform the Owner and to approve the design deviation prior to performing the weld built-up.
thanks mk3223.
Exactly was a vendor error. I am in charge to approve the design deviation.
Sorry, I don't know any detail process or what will happen to this tank in the future. And, I wonder if I can convince all parties, e.g. Eng'g, O&M, etc., to accept the deviation.
The bottom line, I still think the vendor needs to correct the fabrication error.
If you have a weld procedure and a qualified welder for the large gap, submit your plan to the owner, weld it up and do the NDE, should be OK. Otherwise, cut the plate short by 24" or so and put in a new square short plate.
thanks for the answers.
I will do the welding in the large gap with the owner authorization.
Thanks again.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
