Multiple centrifugal pumps suction manifold
I have this question (see attchament):
1. a common supply manifold for 2 groups of delivery pumps
2. First group consisting of 1 ON and 1 reserve pump, with a dedicated delivery piping system. This system already exist and running well.
3. Second group consisting of 3 ON and 1 reserve pumps (parallel system), with a dedicated delivery piping system
What kind of problems can I expect for the pumps?
Thanks for your suggestions.
RE: Multiple centrifugal pumps suction manifold
Q: Is it correct the discharge pipe size same as the suction pipe? Is the pipe sizing met pump hydraulic requirements?
Hello Hartur0,
I have seen enough balancing problems of parallell pumps to raise a warning finger! It might turn out as a smooth operation at first try, but:
If two or more identical pumps in parallell shall perform equally, eg. pump equal amount of liquid, they must have equal amount and pressure of liquid at intake. This could easily differ by a single line (even somewhat oversized) feeding a row of intakes. First and second intake might dominate.
The same problem might occur at output side. First pump might dominate, giving a full pipe and pressure and the other pumps less.
To avoid feeding problems, skew loads of pumps and hammering problems: correct sizing of pumps and piping, regulating possibillities, correct piping layout and design, correct type (softclosing!) and placement of checkvalves, correct outlet (ending) of pipes, air outlet and vacuum protection valves correctly sized and placed.
Good luck!
