How to setup visual studio 2013 & 3DExp to make VSTA macro
Hello all,
I am trying to do some investigation on the capabilities of VSTA macro in 3DExperience 2018x.
My issue is any time I launch the test code it crash.
I had just create a simple VSTA library :
Then I open it and I have this code :
CODE --> C#
using System;
namespace Macro_library_VSTA00000003_vst_1891079_00000003_A_1
  public sealed partial class ThisApplication : ObjectModelAgentLib.CATIAEntryPoint
     public static void CATMain()
        // Debug entry point, not visible from the host
        CATIA.SystemService.PrintToStdout("Hello, World! C#");
The I click on the Start button in VS after like 30s VS close itself with no message and nothing is shown in the 3DExp app. Same behaviour with .NET code.
Do you guys know what should I look at ? May be I miss a setup to be able to test my code.
Thank you.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Strategies to Secure Connected Cars with Firewalls
White-hat hackers have demonstrated gaining remote access to dashboard functions and transmissions of connected vehicles. That makes a firewall a vital component of a multilayered approach to vehicle security as well as overall vehicle safety and reliability. Learn strategies to secure with firewalls. Download Now
White Paper - Model Based Engineering for Wire Harness Manufacturing
As complexity rises, current harness manufacturing methods are struggling to keep pace due to manual data exchanges and the inability to capture tribal knowledge. A model-based wire harness manufacturing engineering flow automates data exchange and captures tribal knowledge through design rules to help harness manufacturers improve harness quality and boost efficiency. Download Now
White Paper - What is Generative Design and Why Do You Need It?
Engineers are being asked to produce more sophisticated designs under a perfect storm of complexity, cost, and change management pressures. Generative design empowers automotive design teams to navigate this storm by employing automation, data re-use and synchronization, and framing design in the context of a full vehicle platform. Download Now
eBook - Simulation-Driven Design with SOLIDWORKS
Simulation-driven design can reduce the time and cost of product development. In this engineering.com eBook, we’ll explore how SOLIDWORKS users can access simulation-driven design through the SOLIDWORKS Simulation suite of analysis tools. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
