managed application ?
Ehaviv
Computer
IL
Hi
What means managed application.?
Do this relates to nxmanager?
Depends in with context is mentioned. But usually yes.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX12 / TC11
Ronald Thank you.
If possible I need more explanation
About this.
As NutAce mentioned, it depends on the context; .net uses the terms "managed" and "unmanaged" code. If you are using a .net language, the .net framework helps to "manage" your code by taking care of some tasks that would otherwise be left up to the programmer.
www.nxjournaling.com
Cowski thank you very much.
