How to model this Joggled sheet in Catia V5 Sheet Metal Design or Aerospace Sheet Metal Module?
Trying to model a surface/web with corner joggle on both sides. Best to illustrate it with a picture.
What I've omitted from the above drawing is the fillets that I want near the joggle i.e. in the sectional views, I want fillets on both sides of the joggles. Did not show it in the drawing because it is tedious to draw it in Word. The offset distance I am thinking right now is around the value of the plate thickness (0.080in).
So far, I've been able to create a surface stamp with parameters as shown below
The fillets on the inside (R1, R2) is missing and also if I reduce the height to equal to sheet metal thickness (0.080in), Catia V5 gives me an error. If I try to include even a small radius value other than zero, Catia gives me an error of not being able to compute the fillets between the stamp & its support.
Just to give additional info, I made a closed rectangular sketch of the outlines where I want the stamps/joggles & used Surface Stamp command.
Hoping to get some tips on how to model the above.
RE: How to model this Joggled sheet in Catia V5 Sheet Metal Design or Aerospace Sheet Metal Module?
hi, you cannot place a surface stamp in a corner...
model it in the middle of a sheet, use a cut-out to retain the quarter you want.
lwolf
regards,
LWolf
LWolf,
Thanks for your reply. Your suggestion worked beautifully.
3D Scanning in the Automotive Industry
With over 100 years of production history, the automotive industry has been at the forefront of manufacturing technology since its inception. Whether the transformative technology of the day was the assembly line, the integration of robotics into the manufacturing process, or the switch from steel to aluminum frame chasses, the automotive industry has consistently implemented advanced technology into its manufacturing and production workflow to improve manufacturing and product performance. Today, the same is true. Download Now
Green light on lidar: Developing low cost systems for autonomous vehicles
Lidar has been around for quite some time, but to date, it’s been custom—and expensive. Right now, there isn’t a clear-cut solution that’s suitable for all applications, such as lidar in autonomous vehicles. As they explore options, optical and mechanical engineers are forced to make choices and tradeoffs during the design process. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
