Contact US
Ball Valve: sour gas service: 16" - 24" size range, 600#, trim material Inconel 625
Dear Friends,
plz suggest me is ball material for subject case is solid Inconel or shall be CS(A105N) with alloy 625 weld overlay
Iranna
RE: Ball Valve: sour gas service: 16" - 24" size range, 600#, trim material Inconel 625
As either solid Inconel valve or CS w/ Inconel overlay valve are suitable for the application, the valve cost and the lead time can be the factors for the material selection.
Thank you so much for the clarification.
I agree with mk3223, but note that limitations might be end users requirements and demand for certifications, Inconel overlay most commonly will be certified by tests and demanded done by qualified welders with welding certificates for the process.
Tungsten carbide coating is carried out on ball and seat surfaces to increase the hardness of the surfaces for wear
resistance.
want to know the above requirement is mandatory & where it is specified?
Iranna
Iranna Shettar,
The last posting seems a new question unrelated to the original question.
And, for a better answer, suggesting to start a new posting, and elaborate a little more, e.g. the valve application, process conditions, etc.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
