VAV Actuator Torque
VAV Actuator Torque
VAV Actuator Torque
I want to ensure whether the actuator installed at the VAV boxes has the correct Torque. The VAV box is quite old and not started since, last 2 years and manufacturer also not responding.
Static Pressure is 600 Pa, Flow - 1100 L/s, VAV neck radius - 120mm, Multiple blade.
RE: VAV Actuator Torque
Have the actuators not been started or maintained for years you should of course have a look, clean, lubricate and test locally without load to see if they function at all first. Then test at full load.
What does local technical labels tell you?
eBook - Efficient and Effective Production Support with 3D Printed Jigs and Fixtures
Jigs and fixtures offer manufacturers a reliable process for delivering accurate, high-quality outcomes, whether for a specific part or feature, or for consistency across multiples of parts. Although the methodologies and materials for producing jigs and fixtures have evolved beyond the conventional metal tooling of years past, their position as a manufacturing staple remains constant due to the benefits they offer. Download Now
Overcoming Cutting Tool Challenges in Aerospace Machining
Aerospace manufacturing has always been on the cutting edge, from materials to production techniques. However, these two aspects of aerospace machining can conflict, as manufacturers strive to maintain machining efficiency with new materials by using new methods and cutting tools. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
