Hello all,
I am doing off design performance prediction of steam turbine at different load. But I am unable to predict the two main key parameters i.e isentropic efficiency and outlet pressure. I have used stodla elliptical correlation but it doesn't fit good with the given HMBD of steam turbine manufacturer.
Turbine detail :
60MW extraction cum condensing turbine with two HP heater, 1 deaerator, 2 LP heaters and one condenser
Can any one suggest any excel sheet or pdf doc. Which will be helpful for me during calculation.
Turbine detail :
