Ceiling return above electric baseboard convector...good?bad?
drka0tic
Hi all,
I am designing the HVAC for a high-end residential apartment in NYC. The apartment is served by dual-temp 2-pipe fan coil units ducted throughout the space. The envelope is high-percentage glass so we also have electric baseboard heating.
The interior designer has requested to locate the air return slots in a window pocket right above the baseboard heaters.
I am thinking this may affect the natural convection from the heaters (e.g. prevent warm air from reaching the occupied space).
I have prepared a sketch (see attached).
Should I be concerned? Any comments/suggestions are welcome.
tia
Henry
 https://files.engineering.com/getfile.aspx?folder=a354fb02-4379-452c-933f-f0fd7de48346&file=Pages_from_MECH.pdf
Increasing the air velocity on the window will increase the window heat transfer by decreasing the film coefficient.
The return air will help with counteracting the draft.
Seems like a good design to me. It should work well for both winter and summer.
