Accessible to Wiring
According to the NEC 2017 section 314.29 "Boxes,conduit bodies and handhole enclosures must be installed so the wiring is accessible without removing any part of the building or structure"
If that is the case why do engineers show boxes above hard ceiling (gypsum) with no access panels? I usually witness access panels only where a junction box is located above the ceiling however this code section doesn't state pull or junction boxes. Is this code section stating you can't have any box in an accessible ceiling?
RE: Accessible to Wiring
If you can access the box thru its cover from the attic then the rule is met.
Keith Cress
What Keith said.
There must be an access to the attic.
You may have to crawl a long way to the JB.
If there is no access above the ceiling then there must be an access panel below the JB.
An electrician who takes pride in his trade will try to avoid hidden boxes.
Sometimes it can't be avoided.
Bill
"Why not the best?"
Jimmy Carter
3D Scanning in the Automotive Industry
With over 100 years of production history, the automotive industry has been at the forefront of manufacturing technology since its inception. Whether the transformative technology of the day was the assembly line, the integration of robotics into the manufacturing process, or the switch from steel to aluminum frame chasses, the automotive industry has consistently implemented advanced technology into its manufacturing and production workflow to improve manufacturing and product performance. Today, the same is true. Download Now
Green light on lidar: Developing low cost systems for autonomous vehicles
Lidar has been around for quite some time, but to date, it’s been custom—and expensive. Right now, there isn’t a clear-cut solution that’s suitable for all applications, such as lidar in autonomous vehicles. As they explore options, optical and mechanical engineers are forced to make choices and tradeoffs during the design process. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
