Contact US
Rotary Vane Air Pump Calculations
Hello together,
I need some support.
I need a formula set for the volumetric, mechanical and overall efficiency and power calculations for a Rotary Vane Air Pump, which has 4 vanes and a circular cam ring / circular rotor, located eccentritically.
One other question, how should I select a dc-motor for such a pump, i mean mathematical calculations for load-source balancing, how could this be done ?
Thanks.
RE: Rotary Vane Air Pump Calculations
Ask the vendor.
I don't think you can calculate these things, it is a case of measuring actual air pumps (usually called compressors or blowers).
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
