Hidi listing window
Hidi listing window
Hidi listing window
Hi
When my journal start the information
Window appears and stay open
Until journal ending.
Is it possible to hide or minimize
The window?
Thank you.
RE: Hidi listing window
I'm pretty sure that there is a method in the NXOpen API that will close the window; however, I think this will also clear the information in the window. If you just want to minimize the window, you'll probably need to dig into the Windows API.
www.nxjournaling.com
Cowski
Hi and thank you.
Actually after a digging and found nothing.
I used to write to a file.
That's prevent openings the window.
White Paper - Effects of AIA Quick Guide to UL 489 or UL 1077
The function of a circuit breaker is to provide overload (thermal) and short-circuit (magnetic) protection to a circuit and its downstream components. A circuit breaker functions like an airbag in a car, protecting circuit components and people by tripping the circuit to interrupt the current flow if it detects a fault condition in the control system. Download Now
White Paper - Guide to Integrate Large-Format Additive
As with any new technology, getting into large-format 3D printing begins with investigation. The first question may be a simple one: what does “large-format” mean? For 3D printers, “large” is a relative term. Many extrusion-based (FFF) 3D printers are referred to as desktop machines, because they fit on table space. Some of these have very respectable build volumes – but when it comes to “large-format,” the machines will need their own dedicated floor space. Large-format 3D printers have significant build volumes and are most often found in professional settings, like manufacturing facilities and R&D centers. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
