MCB with high kA rating
In Distribution board, I seen kA (SC) rating of 415V 3P 32A MCB as 25kA which is more than designed for the panel (as compare to panel SLD 10kA)
What could be the consequences for selecting higher kA MCB?
RE: MCB with high kA rating
Nothing really.
25kA rating in place of 10kA rated MCB is no problem.
If it happens to be other way round, it will have dire consequences.
Thank you..!!!
3D Scanning in the Automotive Industry
With over 100 years of production history, the automotive industry has been at the forefront of manufacturing technology since its inception. Whether the transformative technology of the day was the assembly line, the integration of robotics into the manufacturing process, or the switch from steel to aluminum frame chasses, the automotive industry has consistently implemented advanced technology into its manufacturing and production workflow to improve manufacturing and product performance. Today, the same is true. Download Now
Green light on lidar: Developing low cost systems for autonomous vehicles
Lidar has been around for quite some time, but to date, it’s been custom—and expensive. Right now, there isn’t a clear-cut solution that’s suitable for all applications, such as lidar in autonomous vehicles. As they explore options, optical and mechanical engineers are forced to make choices and tradeoffs during the design process. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
