Contact US
Nozzle Flange modification in API 650 Tank (Post hydrotest tank)
I have an issue with the bolt hole orientation of a nozzle flange. Construction has not taken care to straddle the bolt hole orientation with the vertical centerlines of the tank. The mixer flange when tried to fit with the tank nozzle flange, the bolt holes were offset by 20 mm. Now we want to cut the flange, rotate the re fit-up the flange and weld it. I want to know the acceptance clauses in API-650 & API-653 to support this to get client approval.
RE: Nozzle Flange modification in API 650 Tank (Post hydrotest tank)
I don't think you'll find this well addressed in either standard.
First off, note that API-653 applies only to tanks that have gone into service, IE, have had product in them. That said, you could look into what does or does not constitute a "major repair" that requires a re-hydrotest per API-653.
API-650 gives you an option to omit hydrotesting with other kinds of testing. It doesn't say you can do half-and-half, but there's no logical reason that couldn't be done- it's be an owner call as to the acceptability of that.
Simplest solution if conditions permitted would be to fab up an adapter spool with two flanges rotated by the appropriate amount.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
