machining a large tapered bore in a NiHard grinding roll.
Tmoose
We routinely rebuild Pulverizer/bowl Mill "journals."
Two of the grinding rolls/tires we received last week have curious features in the bores.
Instead of the two typical smooth bands with a relief in the middle, these rolls have what look to be serrations cast in the bands.
I'm thinking if a cutting tool is used to "hard turn" the finished roll bores those serrations would make a horribly interrupted cut.
Maybe if that roll OEM grinds the finished bores having to remove only about 50% as much material is a benefit.
Has anyone seen similar details in difficult to machine materials.
 https://files.engineering.com/getfile.aspx?folder=2df344a0-2b4e-4d1c-a1b5-6e911fa4e6c2&file=Roll_A_and_C_bore_DSC00368_shrink_and_crop_medlye_.jpg
