Checkmate
Checkmate
Checkmate
Hello all
Is it possible to insert two features in the mqc_askFeaturesByType code? As for example blend and a face blend, as they both are blend types.
RE: Checkmate
The answer that i found is:
CODE -->
$feats << mqc_askFeaturesByType( "BLEND" )+mqc_askFeaturesByType("FACE_BLEND" );
RE: Checkmate
But do anyone know why, when using mqc_askFeaturesByType("FACE_BLEND"), with the mqc_askBlendRadius() the face blend would give me a value of -1 in the radius, but with the edge blend it gives me the right value of the radius.
RE: Checkmate
As per docs mqc_askBlendRadius() will return the blend radius of Edge Blend tag. So a face blend tag will be invalid.
Suresh
www.technisites.com.au
RE: Checkmate
Thank you for your answer!
White Paper - Effects of AIA Quick Guide to UL 489 or UL 1077
The function of a circuit breaker is to provide overload (thermal) and short-circuit (magnetic) protection to a circuit and its downstream components. A circuit breaker functions like an airbag in a car, protecting circuit components and people by tripping the circuit to interrupt the current flow if it detects a fault condition in the control system. Download Now
White Paper - Guide to Integrate Large-Format Additive
As with any new technology, getting into large-format 3D printing begins with investigation. The first question may be a simple one: what does “large-format” mean? For 3D printers, “large” is a relative term. Many extrusion-based (FFF) 3D printers are referred to as desktop machines, because they fit on table space. Some of these have very respectable build volumes – but when it comes to “large-format,” the machines will need their own dedicated floor space. Large-format 3D printers have significant build volumes and are most often found in professional settings, like manufacturing facilities and R&D centers. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
