Contact US
Bare shaft Vs Worm Gear actuator
Can someone tell me the difference between bare shaft and worm gear actuators please. How to choose for my application?
Thank you
RE: Bare shaft Vs Worm Gear actuator
A bare shaft actuator is normally used with operational media air, gas, hydraulic oil or water. A wormgear actuator is normally used for electrical operation.
Pneumatic, bare shaft (linear) actuators are usually selected for smaller valves, larger number of valves in plants, faster openings and shutdowns, and repeated larger numbers of operation per time cycle, but also used for larger valves.
Electric operated valves have had a number of improvements the last 30 years, and are now more than previously covering areas dominated earlier by pneumatic valves, especially because of the integrated control possibility. (But not only)
Wormgear actuators, with the correct electrical actuators, can operate more precise, be stopped in midway positions, open slow and continue faster, but also be of simpler (and cheaper) construction for fairly fast opening and closing. Suitable for valves from (say) 150mm and up to largest and up to highest pressure classes.
With modern electrical actuators complete 'internet of things' units can be supplied as an integrated part of the actuator saving a lot on cabling and external control units.
Actuators should be selected on principle best price over lifetime, including maintenance and operation cost. Detailed valve application and construction, operation cycles per time unit and operation time without required maintenance, max/min acceptable closing and opening time (money saved on electrical actuator if geared down) etc.etc.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
