Multiple sheets or Multiple drawings
Hello all,
Looking for a bit of advice.
In NX it is possible to create One drawing with multiple sheets, or you can create multiple drawings with one sheet each.
What would be the pro's and con's for each possibility?
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX12 / TC11
RE: Multiple sheets or Multiple drawings
See attached movie Link that shows you how to accomplish this under nx10. I showed three methods that accomplish the same task. As far as I can see there is no advantage to "create multiple drawings with one sheet each".
Quote (NXerGeneration)
Thanks for the movie but I know how to do this of course.. :)
NX9 / TC10.1.2
From a configuration management point of view, all of the sheets make up the drawing package. The easiest way to control them with the same revision and release is as a single drawing file.
Ben Loosli
We used the master model concept in Native previously. We have a customized BOM per sheet and the sheets follow work centers. ie: laser, fabrication, assembly. We make separate specifications for each drawing and they are all under one item in Teamcenter.
NX 1847
TC 11.5
White Paper – Your Construction ERP RFP Checklist
Selecting business software for a medium to enterprise-sized construction concern is extremely challenging in large part because most enterprise resource planning (ERP) suites originated in the world of repetitive manufacturing and are therefore a poor fit for a project and asset-centric business. However, midsize to large contractors need the predictable, auditable processes that ERP delivers. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
