Display Descriptive Part Name In Graphic Window
Currently running nx10. I remember in older versions of NX/UG there was a way to display assembly Descriptive Part Name right in the Assembly Part in NX Graphic Window. Does any one remember the trick to achieve this??? It would show up similar to how the dimension measurements are displayed, see attached image.
RE: Display Descriptive Part Name In Graphic Window
Menu -> preferences -> visualization -> names/borders, then turn on the "show object names" option ("work view" should work well).
www.nxjournaling.com
Thank you sir. This worked like a charm.
White Paper - Effects of AIA Quick Guide to UL 489 or UL 1077
The function of a circuit breaker is to provide overload (thermal) and short-circuit (magnetic) protection to a circuit and its downstream components. A circuit breaker functions like an airbag in a car, protecting circuit components and people by tripping the circuit to interrupt the current flow if it detects a fault condition in the control system. Download Now
White Paper - Guide to Integrate Large-Format Additive
As with any new technology, getting into large-format 3D printing begins with investigation. The first question may be a simple one: what does “large-format” mean? For 3D printers, “large” is a relative term. Many extrusion-based (FFF) 3D printers are referred to as desktop machines, because they fit on table space. Some of these have very respectable build volumes – but when it comes to “large-format,” the machines will need their own dedicated floor space. Large-format 3D printers have significant build volumes and are most often found in professional settings, like manufacturing facilities and R&D centers. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
