Type of Pump for Liquiefied Propane
We are working on a project handling products like propane, butane, hexane. The type of pumps being suggested is submersible canned motor (sealless).
The vessel is above ground (4 ft from grade & LLL of further 1 ft)
Pump flowrate is 55 gpm and TDH = 800 ft. Vessel ID = 18' 6" & TL / TL = 55' 6"
Wouldn't a VS6 pump mounted at grade with seal plan 53B be a better solution to the submersible pump, as presently under consideration.
Anybody having such experience can please share your opinion.
RE: Type of Pump for Liquiefied Propane
Your high TDH seems like this may be too much for a single pump circuit transporting these types of liquids ... In my opinion
Sliding Vane pumps have been used in this service for decades.
https://www.corken.com/sliding_vane_technology
IMHO, I would talk to several vendors giving them your design requirements and see if you fit into their product lineup.
Keep us in the loop ..... let us know your final decision ....
MJCronin
Sr. Process Engineer
If this is not an EPC job, ask the Owner's lead rotating machinery engineer to get involved in the decision (and Operations lead also).
Better in terms of??
Cost?
Operation?
long term reliability?
Sealing complexity?
One thing with the pressurized seal case for type 53B is that the product needs to be able to accept the sealing fluid.
The canned motor idea reduces your potential leakage issue to the power cable gland and avoids the complex seal system.
Propane is quite hazardous if it starts to leak and generally you need very good seals to cope with stationary shafts still under pressure.
Johnny Pellin
