Contact US
Guidelines for Cutting Out and Returning a Pipe Segment
We are planning to perform some short temporary cut-outs in 12" sch 160 carbon steel pipe, which was not previously stress relieved.
My concern is the unlocking of residual stresses by cutting in close proximity to an existing weld, causing ovality.
What are the recommended guidelines for avoiding this problem in heavy wall pipe? I am expecting it will be expressed in terms of a minimum number of diameters distance.
Thanks in advance.
"Everyone is entitled to their own opinions, but they are not entitled to their own facts."
RE: Guidelines for Cutting Out and Returning a Pipe Segment
Schedule 160 is a thick-walled pipe.
I have never seen pipe that small a diameter "ovalize" from residual stress from welding. Self-weight at 12 inch diameter is much smaller than the strength of the pipe. (Think instead of a 44 or 72 inch diameter pipe only 1/2 inch thick. Do you see how the self-ovalizing will happen on thin-walled, large diameter pipe instead?)
Now, the opposite? Pipes showing significant movement when cut due to relief of fabrication and fitting up stress? Yes, you should expect such movement - it could be compression or expansion or moment (rotation loads), or a combination of all three - when cutting the pipe. You might be lucky and see no movement. But you should expect the sudden movement when the pipe is cut.
Thanks racookpe1978,
I expect movements upon severing, and we can manage those. And with two cuts we gain a degree of freedom when refitting the segment.
Ovalization of heavy wall pipe is more difficult to suppress without fairly extreme measures.
I think I would attach a heavy friction clamp around the pipe some distance away from the cut.
Tighten the clamp firmly and then tack weld the clamp to the OD of the pipe. This should act as a kind of strong back holding the pipe diameter securely. You can then attach other rigging to the clamp and beam holding the pipe from excessive movement when you finish cutting. Just a suggestion.
Thanks for the suggestions Tmoose.
I'll present them to my team.
If it is only to prevent ovalizing, and you don't care about relative rotation, you can weld two half-circles on the pipe that stays. After welding in the pup piece, grind away, PT/MT and done.
Size of the "collar" to be determined, and placed at a short, but reasonable distance away from the cut of course.
I've done this on much thinner tubes, no idea if this is feasonable on a sch.160...
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
