Contact US
Best o ring material for marine heat exchanger
I am looking for a recommendation re the best O ring material to use in a marine heat exchanger.
The liquids are sea water and antifreeze (50% ethylene glycol/water). Normal temperature is 180F with 230F maximum.
The problem that currently exists is that the o rings take a set and start to seep. Once that happens the aluminum housing corrodes and damages the copper cooling bundle. At this time I don't know the assembled dimensions as the one housing I have is too corroded to measure. I will have another one later today.
I don't know what the existing material is however the manufacturer specifies a 24 month replacement interval. Given the amount of work involved in changing them out the actual cost of the o ring is probably not a factor.
Thanks!!
RE: Best o ring material for marine heat exchanger
EPDM would be the material of choice for water and water with anything that dissolves in it. 70 durometer EPDM is fairly standard, set-resistant stuff. The peroxide-cured epdm's are a bit more set resistant, and cost a bit more.
Oh, just one thing - never let standard petroleum products (oil, grease, fuel) get on epdm, it will soften and swell. If you need a lubricant for installation, use silicone grease, or plain old soap and water, or water and glycol.
You may have other problems.
If you allow sea water to get hotter than ~140F, the salt will plate out on all metal surfaces, and eventually clog the pipes.
You may need bigger heat exchangers and higher seawater flows.
Mike Halloran
Stratford, CT, USA
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
