Have any geotech. guys got experience with systems aimed at protecting piles from slope creep in a deep, unstable soil profile?
I'm investigating a proposed new highway alignment in which one of the slopes is very dodgy, approximately 1 000' in length, 15degree angle and underlain by 40 to 50' of fat clay over shale bedrock. The trees on the slope are all buckled and I am confident the slope has undergone a number of cycles of deep failure, as well as continual surficial creep. Stability analyses give factors of safety around 1.0 for deep failures in the saturated condition. The slope movement would be driven by saturation cycles- current investigations show it to be relatively dry.
The slope occurs along a bridge section of the proposed highway- my concern is that conventional piles will shear in the long-term. I've installed an inclinometer and will be monitoring slope movement- we're currently at the preliminary design stage so further investigations and monitoring would follow.
Point is, I don't expect major movement of the slope to be on-going; rather, I expect spikes in movement periodically (every 5 to 10 years say). The monthly inclinometer monitoring may therefore be misleading.
On a similar slope in our area, an historic bridge was constructed across a major landslide, in which instance they sunk large-diameter elastic concrete shafts (caissons) down to bedrock and installed piles within these caissons, which were sized to allow 5' of movement before coming into contact with the piers. Anyone ever used similar systems? Can they still be economic and if not, are there any structural alternatives? My soil volumes are far too great to consider stabilizing the entire slope.
Last note- realignment of the route would be very difficult, probably impossible due to the topography and land-use constraints.
Cheers,
Mike
Cheers,
Mike
