materials selection for pipes
I would like to select a material for pipes which will transport saline water. However, I can't find materials selection charts for corrosion resistance.
Where can I find (books, articles) a chart or table which compares several engineering materials according to these metrics:
-Corrosion rate (mm/year or mm/month) on pure water and on saline water,for common engineering materials
-Corrosion potential, in general, for common engineering materials.
I tried to find this information, but I could only find a few results for very specific materials.
Thank you,
Best regards,
AndradeLopes
RE: materials selection for pipes
The preferred approach is to identify standard industry practice, not attempt a solution from first principles. Many folks have before us a cleared the path.
"Everyone is entitled to their own opinions, but they are not entitled to their own facts."
Selecting the best piping material for liquid transport depends on many factors besides corrosion resistance.
Some of these are:
- Bending Strength, with attention paid to span lengths and support types
- Surge pressure in the system and the strength of the welded joint or coupling attachments
- Pressure drop and overall lifetime cost of pumping
- Valve and flange costs
- Stiffness and resistance to vibration.
Your "saline water" can mean many things ...
Generally speaking, I suggest that you consider complete plastic PVC/CPVC systems first (only if your maximum operating temperatures are low) then go to the nickle based alloys based on cost and the pREN number.
Flange and Valve costs for both types of systems are FAR MORE than the carbon steel flanges !!!
Also consider the cost of installation .... plastic systems are cheaper to install
More information in the 7th edition of the Classic ...:
https://www.amazon.com/Piping-Handbook-Mohinder-L-...
MJCronin
Sr. Process Engineer
Try the Handbook of Corrosion Data published by ASM International.
Can you use non-metallic? Either plastic or FRP?
With metals you will need to know the minimum pH, max temp, and max Cl levels.
If the pH is below 6 and the Cl above a few thousand ppm then you are talking about high alloy (expensive) materials.
For saline water oxygen content and temperature is also critical.
Very low (ppb) levels of oxygen and then you can use Carbon steels, highly oxygenated warm / hot sea water and you're into plastics or exotic (i.e. super expensive) materials.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
