Hello!
We have a 4160V, 500HP, 1200RPM 5000 frame electric motor used in vacuum pump application. It is belt driven. The motor took a crap after the DE bearing temperature shot over 300 degrees and the shaft seized up. We pulled the cap and saw the a substantial amount of grease on the windings. We saw that the shaft was also damaged. As if the inner race spun on the shaft. We got a report back and the shop said the reason the motor failed is due to over greasing. The bearing housing fit on the DE is also damaged. So I believe it spun on the shaft and it spun in the housing.
The kicker is that the motor was just rebuilt 4 months ago and at that time both bearing end were sleeved. So we believe the sleeves didn't hold up and the shop is blaming us because they don't want to warranty a $50k motor.
So my question is if over greasing can cause a bearing to lose its fit. I know a over greasing is the major failure of bearings. I don't have much experience so I don't know in what ways over greasing can damage to a bearing. The DE bearing is a NU324 and the ODE is a 6318 insulated bearing.
