Does NX have an automated clearance check feature for a range of motion?
I am working on a tube support inside a crankcase that is positioned near the crankshaft. I’d like to give the crankshaft one full rotation and find the minimum clearance between the crank and the support at every five degrees or so.
I was an I-deas user for many years and I remember being able to create animations with sequences in Master Assembly. There was an interference command that would automatically measure the distance between two components at every sequence in the animation. So, If I set up the sequences to rotate the crankshaft every five degrees for one rotation, it would give me a list of measurements for every sequence.
Does something like this exist in NX?
I am using NX 11.
Thanks!
RE: Does NX have an automated clearance check feature for a range of motion?
This function should exist in simulation or animation designer.
Didier Psaltopoulos
http://www.psi-cad.fr
You should be able to create a "motion envelope" in the "Assembly sequence" , then check between the resulting faceted volume and the surrounding.
I just tried this, and, it requires a license that i seem not have,
but there are no records of what license is missing, neither in the NX syslog nor the licenseserver log. Weird.
Tomas
I gave it a try and wow, that is amazing! Thank you Toost for teaching me something today!
White Paper - Effects of AIA Quick Guide to UL 489 or UL 1077
The function of a circuit breaker is to provide overload (thermal) and short-circuit (magnetic) protection to a circuit and its downstream components. A circuit breaker functions like an airbag in a car, protecting circuit components and people by tripping the circuit to interrupt the current flow if it detects a fault condition in the control system. Download Now
White Paper - Guide to Integrate Large-Format Additive
As with any new technology, getting into large-format 3D printing begins with investigation. The first question may be a simple one: what does “large-format” mean? For 3D printers, “large” is a relative term. Many extrusion-based (FFF) 3D printers are referred to as desktop machines, because they fit on table space. Some of these have very respectable build volumes – but when it comes to “large-format,” the machines will need their own dedicated floor space. Large-format 3D printers have significant build volumes and are most often found in professional settings, like manufacturing facilities and R&D centers. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
