Revit LT vs Revit
Revit LT vs Revit
Revit LT vs Revit
We are just getting started in Revit and are looking at LT vs the full version.
Is Revit LT suitable for structural work? I looked at the comparison matrix for LT vs the full version and it says that LT does not do : Slanted Columns, Trusses, Advanced Steel Connections, Reinforcement / Rebar Modelling.
I'm not sure what it considers trusses, but other than that it doesn't seem to be a deal breaker (maybe slanted columns will be an issue at some point).
If others have used LT, is there an issue with collaboration?
Thanks!
EIT
www.HowToEngineer.com
RE: Revit LT vs Revit
We treat LT like a Revit Viewer. Lots of little things it either won't do or doesn't let you do as efficiently.
LT is basically a gateway drug, enough to get you hooked and think its enough, but after some time you will need to move to harder drugs.
For me, the main drawback is precisely the limitations on collaboration:
- No worksharing. Only one person can pee in the pool at one time.
- No copy monitor to see if things are changing and clashing.
- No ability to customize the visibility of a linked model. This one hurts badly even if you're not doing true collaboration.
Higher end structural modelling toys I could live without for the rather massive difference in price. LT basically only has a chance of working for your if you're not collaborating with a client's model which is rare.
Revit LT does not allow you to automatically create a column schedule = deal breaker
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Manufacturing the Cars of Tomorrow
In this ebook, we'll explore how additive manufacturing is going to transform the way cars are made. This includes commentary from thought leaders such as Ford's CTO, Ken Washington, Customer case studies of ways 3D printing is being used today, and a variety of part examples where 3D printing is already impacting how automobiles are made. Download Now
White Paper - Smart Manufacturing for Semiconductor
New technologies and approaches present great opportunities for semiconductor manufacturers to achieve high levels of innovation, yield and improvement. This white paper explores some of these cutting-edge technologies and how they can be applied effectively in the semiconductor industry. Read about how Smart Manufacturing is transforming the semiconductor industry. Download Now
White Paper - Analysis and Simulation in Aircraft Structure Certification
Organizations using simulation and analysis tools effectively see the benefits in their ability to achieve certification faster and with drastically less total cost than those who do not maximize these tools. Read this White Paper to learn about how digital tools such as analysis and simulation help in aircraft structure certification. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
