Hydrostatic test equipment - initial test and inspection
I have a flanged ring test piece that will be bolted to a pressurised item, to hydro test it in workshop at 1630psi with water, prior to return the pressurised item to service after rebuild. Less than 100 uses through life.
What are the requirements for initial test of the flanged ring test piece (mild steel,no welds involved)? It is difficult to test it to greater than 1630psi without overstressing one of the production item or building an imitation production item as a test piece for the test piece.
Also what is the usual practice for periodicity of inspection of pressure test equipment?
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper – Data Security and Know-How Protection
Our data is constantly exposed to the danger of being intercepted or stolen as it wends its way over global data networks. Data security measures and measures for protecting intellectual property should not, however, first be implemented when data is exchanged – companies must lay the foundation for these measures within their own organization. Download Now
White Paper – Collaboration in the PLM Context
The influence exerted by the Internet of Things (IoT) means that there is a steadily growing need for collaboration in industry. Partners from new industries and areas of application need to be integrated in cross-company business processes to ensure that the lifecycle of smart, connected products can be managed from end to end. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
