Inconel 718 vs Inconel 718 plus
Joe Chen
New member
TW
Dear All
What is the difference between INCONEL718 and INCONEL718PLUS manufacturing (lathe/milling)
(eg rpm/feed/depth/machining time), could we use the same parameter for 718 to work 718 plus,
thanks.
What are the properties of Inconel 718+ and how do they compare to regular 718?
Unless the nickel or chromium content is significantly higher (or lower) I would suspect that machining would be similar.
Ben Loosli
